Thanks Pete for the supplemental information but I think I have the correct parts as both gauges have the same male 1/8" pipe threads and I'm using the original brass connector between the original 1/8" steel line with the ferrule and the gauge unit. Don't have a problem with the fitting working just fine it is just that too much tube is past the ferrule which contacts the back of the gauge without sufficient clearance to permit the ferrule to seal against the sealing surface within the brass connector. I certainly appreciate the part no. information and will run a copy to keep in my parts catalog. Thanks for sharing, Hal.
