Re: Oil Pressure Gauge Issue - Help Needed.
Posted by pete 23 on April 03, 2014 at 19:52:24 from (74.33.94.238):
In Reply to: Oil Pressure Gauge Issue - Help Needed. posted by farmallhal on April 02, 2014 at 16:46:30:
Just some more information on hooking up the new replacement oil pressure gauges that come with a male pipe thread. The CASEIH part number for the adaptor fitting is 257523R1 and if you need the nut with ferrele that slips on the pipe like original the number is 19984R1.
That nut is the same style but smaller size just like used on the original gasoline lines on all the H and M's and numerous other IH tractors. Seems to be a lot of confusion over that as IH did not use flared fittings or more conventional ferrele type with the male threaded fitting where a female threaded nut screwed onto the male . The type IH used is difficult to find in ordinary parts stores or hardware stores.
