Posted by HillBillyRockStar on April 06, 2014 at 10:34:44 from (71.82.107.195):
In Reply to: Farmall 450 4.25 pistons posted by HillBillyRockStar on April 02, 2014 at 19:45:11:
The bore without any sleeves in the block already measures around 4.375. And I am sure it was bored long ago. I pulled the sleeves because they were so pitted and the bore of the block it's self looks good. Ive talked with a couple of Reputable engine builders and was told to look at the water jacket around cylinders and they look good but still have the block sonic checked and if it checks out good measure and order pistons and rings from arias. Hone the block and run pistons on the block. Cheapest way to solve the problem with a good increase in cubic inches and with that horsepower. With the amount of use this tractor gets if it last half as long as stock engine I ll be dead before it's wore out.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
