Re: finally got me a big tractor
Posted by mkirsch on April 07, 2014 at 09:49:32 from (65.199.189.6):
In Reply to: finally got me a big tractor posted by rebelbull on April 07, 2014 at 09:39:20:
I don't know of any place to download a free manual. Printed ones are $20-$30. Do yourself a favor and buy one. It's a mere fraction of what you spent on the tractor.
Did you turn the fuel on before you tried to start it? If not you ran it out of fuel and now you will need to bleed the entire system.
With 1/4 tank of fuel the tractor should run on any angle it will sit on. That's not your problem.
Did you run the glow plugs? Do the glow plugs work? Don't use ether on glow plug engines.
There is air in the steering now due to the leak and you trying to steer it without the tractor running. It may clear up once you get it running.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
