Re: finally got me a big tractor
Posted by Ed3 on April 08, 2014 at 15:36:57 from (70.192.80.8):
In Reply to: Re: finally got me a big tractor posted by mkirsch on April 07, 2014 at 09:49:32:
I second the ether comment. Don't do it on a glow plug engine
bad things could happen
Those old engine need good working glow plugs and they take
a while to Heat up . Not like a modern tractor that only
requires less that 30 seconds.
Once hot they start fairly easy. If they are marginal in any
way you'll crank it to the cows come home and it won't start
Their are some Manuel's on this site, eBay or even the local
oh dealer
Change the filters, bleed the system and make sure the glow
plugs are in tip top shape .
Get the biggest battery you can as one battery is better than
the 2 battery system it had. One battery has less terminals
Carquest has a 1200 amp jumbo car size battery that should fit
by the seat
Good battery clean filters and good glow plugs and your
starting problems will be gone
Good luck with it
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
