Posted by D Slater on April 09, 2014 at 12:14:24 from (184.14.169.134):
In Reply to: 350 t/a posted by jerry4 on April 09, 2014 at 09:08:48:
Slip in direct drive = T/A clutch slipping.
In T/A slip = ramp and roller assembly not locking the T/A carrier from spinning.
Also will add that you can remove the linkage pins from the T/A clutch operating shaft and see if it still slips in direct drive. That's just a check to make sure they don't have the T/A clutch linkage adjusted wrong before replacing the clutch. If slipped for a while it may still need replaced though. Also check for oil leaking out 2 weep holes in the bottom of the center housing. May indicate possible oil on the clutch.
This post was edited by D Slater at 12:52:11 04/09/14.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
