Assuming you had the Flywheel cut to the correct step depth. Both the friction face, and the PP mounting surface must be machined), it sounds to me like the free play is not correct. If the puin is out of the TA clutch, the pedal should move a little more than an inch when pushing it down by hand before the hand pressure builds from releasing the disk. If there is lost motion in the linkage, ot the "rebuilt" pressure plate has failed, the correct freeplay will not work. A warped disk will cause drag, A disk with decomposing friction material will also cause the issue if the material begins to stack up. If the linkage motion is corect, I suspect the Pressure plate. Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
