Re: Farmall 300 clutch problem
Posted by Danny D on April 14, 2014 at 11:08:26 from (172.5.167.25):
In Reply to: Re: Farmall 300 clutch problem posted by Janicholson on April 12, 2014 at 13:11:44:
I have checked everything and the problem is not the linkage, cross shaft, throwout bearing or pressure plate. I wonder if the splines in the new clutch plate have finally nested back into the old wear marks in the shaft? The shaft did not look that bad being a 60 years old. Everything else on the inside looked fine as I had recently taken it all apart. This is the exact problem that prompted me to rebuild the tractor in the first place. Well at least now it is clean and easy to work on.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
