Re: Getting points open to measure gap
Posted by mkirsch on April 15, 2014 at 05:03:15 from (65.199.189.6):
In Reply to: Getting points open to measure gap posted by Massey farmer on April 15, 2014 at 04:10:37:
Care to explain?
How else you going to do it?
You could spend hours bumping the starter trying to get it on a lobe.
The fan belt isn't enough to roll over some of these high-compression 6-cylinder engines.
Why would you take the distributor off the tractor, or rotate it? You just messed up your timing!
