Re: Getting points open to measure gap
Posted by Massey farmer on April 15, 2014 at 05:38:44 from (174.252.33.55):
In Reply to: Re: Getting points open to measure gap posted by mkirsch on April 15, 2014 at 05:03:15:
If he can't turn that little motor on a 200 over with the fan belt
that's the first thing I would address. Second, it's best to be
able to turn the motor over by hand to get it close then turn it a
little both ways while your standing over the distributer to make
sure the points are riding on the highest point of the lobe, not
just close enough while your trying to push a tire and watch. I
dont know if the 200 has a bolt in the front of the crank you
can get a deep socket on or not and turn the motor that way.
He said the crank pully is pressed on so maybe not. Like I
said, it works how he did it, but you said he did it "exactly right"
and I don't believe that statement is true.
