Re: Wide front for 300 Farmall
Posted by rustyfarmall on April 16, 2014 at 08:01:45 from (208.126.186.41):
In Reply to: Wide front for 300 Farmall posted by DeltaRed on April 14, 2014 at 21:29:32:
I also like the "look" of the original cast hubs and rims, but if you're hanging a loader on that tractor, the 6 bolt hubs and stamped steel wheels will hold up a whole lot better, as well as give the option of wide, flotation type tires.
