Re: Is my block done for?
Posted by DK44H on April 17, 2014 at 05:37:54 from (96.31.177.224):
In Reply to: Is my block done for? posted by DK44H on April 16, 2014 at 21:03:20:
Thanks for the encouragement. I've got the cylinders filled with ATF, but the one with the broken sleeve is leaking away. It may be quite awhile before these break loose. I've also got a problem with the shift rails, they are frozen up tight too. The inside of the trans seems ok tho. So I'll have to address that as well. A non running but loose M came with the deal, supposedly ran when parked. Metal is straight and has the single front. I'll let the 400 soak while I try to get that M running. Maybe by then she'll be ready to go. Sometimes I wonder why I put myself thru all this, but once it's done it's all worth it! Definitely a labor of love!
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
