Re: Is my block done for?
Posted by D Slater on April 17, 2014 at 06:04:35 from (184.14.205.2):
In Reply to: Is my block done for? posted by DK44H on April 16, 2014 at 21:03:20:
If freezing water pushed the cylinder wall out its a possible repair if that's the only problem. Unless its sentimental or you want a original block a better option maybe another block if you can get one close at a reasonable price.
If it has the thin wall sleeves, 4.125 pistons sleeves will come out pretty easy in pieces if you break the top flange on the sleeve. Carful not to damage the top of the block or counter bore. Then take something thin that won't dig into the cylinder wall and start going down behind the sleeve. Usually the sleeve will peel on down then remove what's left.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
