Re: Case IH Oil Drain Plug Won't Turn Loose
Posted by clint s on April 19, 2014 at 08:37:54 from (67.242.45.169):
In Reply to: Case IH Oil Drain Plug Won't Turn Loose posted by Charles Beaverson on April 19, 2014 at 08:17:23:
Weld a nut to the bottom of the plug if you have a welder. If not a little heat and some vice grips if the pipe wrench does not work.
