Re: Case IH Oil Drain Plug Won't Turn Loose
Posted by Charles Beaverson on April 19, 2014 at 08:17:23 from (174.60.220.23):
In Reply to: Re: Case IH Oil Drain Plug Won't Turn Loose posted by DeltaRed on April 19, 2014 at 07:57:28:
Thanks for the response. I did think of using a pipe wrench but sprayed it first with penetrating oil. Not sure if penetrating oil does any good or not. I suspect for it to work you must keep spraying every day for about a week. I may only have one shot with the pipe wrench as there is not much left to get hold of.
