B275 clutch adjustment
Posted by Rex Simpkins on April 19, 2014 at 16:29:07 from (69.251.237.110):
Working on a B275 with a spicer laycock dual
action clutch, the clutch wants to grab when the
pedal is fully depressed.
I have the manuals but I want to make sure I am
right.
The three screw adjusters on the outside end of
the fingers need to go in in order for the shaft
end of fingers to go out thus moving the pressure
plate away from clutch disk a litle more when
pedal is depressed correct or not?????????????
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
