Re: B275 clutch adjustment
Posted by JimB2 on April 20, 2014 at 05:29:31 from (173.243.43.98):
In Reply to: B275 clutch adjustment posted by Rex Simpkins on April 19, 2014 at 16:29:07:
Hi Rex,
Years ago on our 434 loader tractor, the adjusting nuts wore a groove in the fingers and by turning the nut 90 degrees the nut was resting out of the worn groove.
See archives at:
https://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=farmall&th=888950
JimB
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
