Posted by rustred on April 20, 2014 at 08:05:41 from (74.214.152.80):
In Reply to: Farmall M Engine posted by IAtractorKid on April 20, 2014 at 06:54:28:
the 140 psi cyl. is most likely from being carboned up. how much oil is the tractor using? should know that as can very well be rings and sleeve wear. you don't need to pull head to check guides, just valve cover.check each cyl. on tdc. any noticeable looseness can be felt by moving top of valve side to side. its not accurate but still gives you an idea of the really loose ones causing grief. meaning that if no noticeable looseness is there then you saved pulling head.as compression is ok. to get rid of carbon in head run tractor at fast idle at operating temp and sniff in water at carb .you can even buy spray in stuff for this. also make sure the carb is set after u adjust valves and points and timing. then do as steve says, work it hard. then monitor the plugs to see if there are burning the regular brownish.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
