Posted by IAtractorKid on April 20, 2014 at 06:54:28 from (184.97.55.91):
OK guys, my aunt finally got her M over to me and I was able to check it out a little last night after getter the Farmhand loader pulled off. She said that it keeps fowling the plugs and is hard to start and runs rough. It looks like oil is weeping out of cylinder 3 from the exhaust manifold and from the head gasket on the other side of the block. I pulled the plugs and cylinder 3 was dripping with oil...the others weren't too bad. She was told to use Autolite 388 plugs, I'm guessing that is hotter than the 386 that I'm thinking it should have? I was VERY shocked with the compression numbers of 130, 122, 140, 125. What do you guys think at this point? Initially I was thinking valves or rings but with compression numbers that high...would it maybe be valve guides instead? Either way I know I'll have to pull the head and pan to inspect and measure everything for wear. Just curious what you guys would be thinking at this point. 46 M with I believe an F4 magneto.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
