Are we talking about a few drips gas when you try to start it with lots of choke, or gas just pouring out all the time?
Put your palm over the carburetor intake. Do you get good suction?
You could have a leaking intake, stuck valves, stuck rings, low compression. The engine needs to create suction to pull the fuel/air mix into the cylinders.
Get a compression checker and do a compression test.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
