Farmall A Runs and dont
Posted by Rod1555 on April 21, 2014 at 11:10:55 from (63.152.236.157):
looking for a little advice. I have a farmall A that is proving to be more difficult than I think it needs to. It will start when I have the throttle open all the way and the choke on. It runs like crazy but if I push the choke in or throttle down it dies instantly. I bought the tractor last fall and it ran fine the guy I bought it from had put 350bucks in the carb in 2012 (I saw the receipt). I have had the carb apart half a dozen times and the governor once and the results have not changed a bit. I did put a new manifold on it and I have taken it off and blown through the ports (grasping at straws). I am accepting any and all ideas thanks
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
