Re: Farmall A Runs and dont
Posted by Tom Fleming on April 22, 2014 at 03:44:44 from (67.20.239.72):
In Reply to: Farmall A Runs and dont posted by Rod1555 on April 21, 2014 at 11:10:55:
Let's make a summary of some of the info that has been posted:
1.) compression, check all cylinders. Should be within 10% +/- of each other
2.) Is the intake leaking anywhere.
3.) is there good gas flow TO the carb. Is the screen plugged where the fuel line goes?
4.) mag can only be adjusted about 10 degrees. It is either in time or 180 degrees out. battery ignition can be adjusted way more than a mag.
5.) valves sticking or out of adjustment.
6.) is the governor working correctly.
You problem sounds like fuel. but checking those other items certainly will not hurt, and will give you absolutely where you are with the key parts of the engine.
