Re: Farmall A Runs and dont
Posted by dej(Jed) on April 22, 2014 at 09:28:09 from (141.189.113.1):
In Reply to: Farmall A Runs and dont posted by teddy52food on April 22, 2014 at 06:43:10:
The needle valve and seat opening and closing is a function of the gas level in the carb. The flow is regulated by the rise and fall of the carb float. If the flow stops before the carb reservoir fills, then you have a clog in the fuel delivery system; ie the line or the carb passage back to the tank has an obstruction.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
