Re: Farmall A Runs and dont
Posted by teddy52food on April 22, 2014 at 06:43:10 from (184.94.175.179):
In Reply to: Re: Farmall A Runs and dont posted by mkirsch on April 21, 2014 at 11:32:59:
You won't get a pencil sized stream for long. It can only flow what comes through the seat which is a small hole. It should be steady for a long time.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
