Sorry about that. I should have remembered to say what it is. 1941 Farmall H. It has a knock when I first start it up. Maybe 3 knocks and then sounds ok for the rest of the day. Oil pressure seems ok and it doesn't use or leak much oil. Only reason I want to drop the pan is to make sure it's not rod or main bearing. I guess it could be in the front of the motor also. First season with this tractor. I just picked 9 acres of corn and it worked well. Used maybe a pint of oil. Every now and then it takes a fit and blows blue smoke for a couple minutes but then clears up.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
