Re: Farmall F-12 update and more problems..
Posted by Mike Androvich on April 27, 2014 at 17:55:23 from (98.28.78.46):
In Reply to: Farmall F-12 update and more problems.. posted by FarmallCT on April 27, 2014 at 16:58:01:
There is a way to lube the fan hub. There is a slotted stud that's kept in place by a jam nut. Turn the fan around until you see it. It's located on the body of the fan hub directly behind the fan blades. Your bearing is probably dry. You are supposed to turn the hub till the opening is sideways, remove the stud, fill with oil till it runs out, then replace the stud. Don't let it run dry! Hope you can figure out what I mean!
