Farmall F-12 update and more problems..
Posted by FarmallCT on April 27, 2014 at 16:58:01 from (70.215.5.58):
I finally got the F12 running again after cleaning out the bypass at the top of the gas
tank which was clogged. I had it running for a good 40 minutes without problems. When I
went to move it, it backed up fine but stalled and seemed like it was under a load when
i put it in second. The spark was weak so I put a new mag i know is good on it and it
started up after a good amount of cranking. My problem is that later it began stalling
like it did the other day like it was flooding except i checked and the bypass is
clean. Its not flooding as bad as before but its still doing it. I have the carb apart
and it appears clean. It seems to only begin giving me problems when i throttle up a
lot. I also have a noise coming from the fan/magneto area that i cant find and i dont
see any grease/oiling points for the fan and it is getting worse.
My question is does anyone have the carb adjustments and the float adjustments for the
normal f12/f14 carb? Also any idea on the noise by the fan? Thanks for all the help,
this is my first F12 and I really appreciate the help. Thanks.
To watch the video search: 1937 Farmall F-12/F-14 Engine Break in Part 2
The engine noise can be heard in it, thanks.
