706 Remote Valve Rework
Posted by Matt Tieken on April 28, 2014 at 18:20:45 from (208.70.40.28):
Ok guys, I reworked the remote valve on the 706 because it started leaking out the back when I was using the loader with an external spool valve. It had a gouge in the o-ring for the detent catch piston.
The valve works great now, the only problem is, it is very stiff. It doesn't return to center like it used to. If I pull back on the valve, it just sticks there. I understand it is supposed to stick with the detent, but it just sticks up or down wherever you put it.
It isn't the end of the world since I had to tie the remote valve back to use the loader. I just like having things work the way they are supposed to.
What could be the problem? I checked everything and it is reassembled according to the shop manual.
