In that case, how easily did the spool go back in. Some times they will make a small hump on the lever end from the linkage touching it and then they will not come out easy and score the body a little if you don't file that hump off. Also, when I put the spool back in I always reach around the front and pull the valve through after pushing it in far enough to get ahold of the end. Other possibility, did you have two valves out at same time and mix them up. Not much else I can think of off hand.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
