There have been a few topics about the H carburetor in recent weeks (mine included). I think the general consensus is that any of the kits will work for either the 50981 or 45108 (originally Kerosene).
If it leaks really bad, just take lower half of the carburetor off (gently) and check the float and needle valve. The float could either be leaking or need to be adjusted. If the the float is still on the top half of the carb, measure from the carb body to the float. I forget the exact measurement at the low point (2-1/8" maybe?), but the high point is - per the manual - 1-27/32". You may have to play with the little tab on the float to get it right. If you gently bend it towards the needle valve, that should raise the float level.
Also clean out the needle valve really good... lots of carb cleaner and compressed air should help.
try that before you buy a kit... I thought I needed a kit and could have realistically gotten away with just a good cleaning and a new float, since mine was shot.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
