Re: M Carb Adjustment
Posted by Janicholson on May 10, 2014 at 04:16:54 from (74.60.94.18):
In Reply to: M Carb Adjustment posted by duckrock on May 10, 2014 at 04:02:33:
Fuel flow must be checked first. If the sediment bowl and lines to the carb flow free, and the needle and seat in the float bowl are opening and closing reliably, the issue might be crud buildup in the carb over winter. To see if it is the air cleaner, remove the hose at the carb. (If it is old, be prepared to replace it, they get brittle. Jim
