M Carb Adjustment
Posted by duckrock on May 10, 2014 at 04:02:33 from (132.3.29.80):
Does anyone have a good set of instructions for adjusting the carb/choke on a M. Mine ran fine all last year. This year it will run fine one minute and spit/sputter/die the next. Playing with the choke/throttle will sometimes make a difference when it starts running rough. First guess is that the problem is air flow.
