Re: Supera ignition problems
Posted by clint s on May 11, 2014 at 16:24:16 from (67.242.45.169):
In Reply to: Supera ignition problems posted by gene bender on May 11, 2014 at 12:43:26:
Just had to change the points on the 200. One had a little bump on it. Cleaned them a time or 2, it would run good for the next few times but then sputtering under load and hard to start. New points set to .020 and she fires right off pretty good now. Ran the disc over the garden and drew a few loads of manure and all seemed good. Am seriously thinking of going with a Pertronix and giving them up. Still having few carb issues, but it is a Carter UT so when funds allow may just get a Zeinith and be done with it
