Re: Supera ignition problems
Posted by gene bender on May 11, 2014 at 12:43:26 from (67.55.226.121):
In Reply to: Re: Supera ignition problems posted by Charlie Seale on May 10, 2014 at 06:48:47:
It ran when you shut it off. Now no spark to the plugs clean the points good and it will run again. Just finished one that had set 5yrs no fire cleaned the points started and ran just fine they can get a film and wont fire that makes two this spring same same no fire cleaned points and they both started and ran.
