Re: 1973 international 3444 diesel backhoe just stopped
Posted by 3444backhoe on May 13, 2014 at 20:31:41 from (166.137.101.159):
In Reply to: 1973 international 3444 diesel backhoe just stopped posted by 3444backhoe on May 12, 2014 at 21:17:18:
Ok I finally had some time to work on the backhoe this evening. I added 5 gallons of diesel. There was about 3 inches of diesel in the tank before I added the 5 gallons.
I installed a new fuel filter. I could not see a way to bleed air from the fuel filter partly because I have still not figured how to get the hood off. I bleed the injector pump (while doing so 1 off the bleed bolt heads broke off. I was able to get it out and found a grease zirt that threaded into it.) I took 1 injector line off the injector and turned the engine over. Fuel squirted out off the injector without much pressure. Put everything back together and it doesn't seem like it's even trying to start. Oh ya I the heater plugged in and a battery charger on it the whole time. I thought tractors were suppose to be simple. What do you think I should try next? For the record I'm not 100 percent sure I got all the air bleed out yet but I was racing the sun and the sun won. I also checked the engine oil and it does not appear that these any fuel in it. Thanks for everyone's time and help so far.
