Re: 1973 international 3444 diesel backhoe just stopped
Posted by jimb2 on May 14, 2014 at 19:41:44 from (99.240.243.222):
In Reply to: Re: 1973 international 3444 diesel backhoe just stopped posted by 3444backhoe on May 13, 2014 at 20:31:41:
Hi, good news that the crankcase oil doesn't smell
of Diesel. If the filter doesn't have bleed screw,
tighten the filter hold down bolt and then hold
the bottom with your hand and loosen the hold down
bolt a couple turns and pump hand pump until fuel
comes bubble free then tighten hold down bolt then
move on to injection pump.
Are your glow plugs working?
Loosen a couple injector lines at the rear of the
pump just a couple turns on the nut and then
wiggle the inject line to break the seal. With
throttle almost wide open, attempt to start
engine, there will be a small squirt of Diesel
come out every time it fires on that cylinder. Be
careful when working on the injection lines as the
Diesel is under 2100 psi and can cause serious
damage to your skin.
Don't crank the starter for more than a minute at
a time and then let it cool off or you will over
heat the starter.
Good luck
JimB
