Re: 47 Farmall M carb problems
Posted by mkirsch on May 15, 2014 at 04:19:34 from (65.199.189.6):
In Reply to: 47 Farmall M carb problems posted by THawk on May 14, 2014 at 15:58:52:
To do what Tom suggests you need to take the carburetor off the tractor. There is a little square peg protruding from the governor tube that needs to fit into a notch in the front of the carb where they bolt together.
It can be a pain to get it right because you have to slide that together at the same time you're trying to get the carb over the studs on the manifold.
