47 Farmall M carb problems
Posted by THawk on May 14, 2014 at 15:58:52 from (98.30.88.154):
HELP! My Dad and I just finished restoring my grandfather's 1947 Farmall M. It was running fine for a while, but now when we try to start, it runs for a bit then shuts off. If I idle up a couple notches, it'll run then slow down and randomly speed up to keep running then shut off again. When I mess with the carb screws, it runs fine, but I have to mess with the carb screws every time I try to start it. I tried to set the carb to factory settings suggested on these forums, but they aren't right for this tractor. I'm not even sure which screw I should be tweaking the most. It runs rich when it runs right. It has new plugs, wires, points, condenser.
