1948 A-V runs (poorly) on 2 cylinders.
Posted by ccaissie on May 16, 2014 at 16:52:55 from (64.222.244.89):
Started this spring, would not fire on 1 & 4.
Then she "come out of it", but misfired a bit and lacked oomph. Idles
fair with idle mix screw all the way in. Rotated
magneto to get slightly better performance.
Now it's back to running on 2 jugs. I had to
retime it before, as there is a chronic problem of
timing slipping, which I'll need to address,
probably now.
It may be a gross timing issue, as the carb is new,
and seemed to run ok last year.
Any ideas on this? Thanks.
