Re: Carter UT/ Farmall 200 no start stall
Posted by clint s on May 17, 2014 at 13:39:38 from (67.242.45.169):
In Reply to: Carter UT/ Farmall 200 no start stall posted by El Toro on May 17, 2014 at 11:12:23:
Could not get it started for anything all morning . Cleaned the points with a $ bill and it fired right up. Drove it home to the shop from the farm ran great. Shut it down and it sat for 1/2 hour, back to not starting again. Cleaned the points again, sure as anything fired right up. Should not have to clean them every time I start it. Any thoughts..........
