Re: Carter UT/ Farmall 200 no start stall
Posted by rustyfarmall on May 17, 2014 at 14:14:41 from (208.126.186.41):
In Reply to: Carter UT/ Farmall 200 no start stall posted by clint s on May 17, 2014 at 13:39:38:
Oil seal in the distributer is letting oil seep in, and it gets on the points. Or possibly, the vent in the oil fill cap is plugged, causing the engine to build pressure, and pushing oil past the oil seal in the distributer.
