Re: At my wits end with needle valves
Posted by gene bender on May 18, 2014 at 02:45:18 from (67.55.226.121):
In Reply to: At my wits end with needle valves posted by Mr. Farmall A on May 17, 2014 at 15:15:33:
You must no be using the little wire clip that attaches to the float so when the float drops the needle will open. Where are you getting parts. Ive been using the 10% blend for like 40yrs since its been here in IOWA i have several As and Bs with Zenith carbs and sure dont have the problems you do engines even set all winter in dirt floor shed and they will start in spring but they are in shape with good starting systems still on 6v just dont see why people have trouble then blame the gas. When i had a place in Colo at 10,000 ft near Gunnison tractor would start every spring after setting there all winter.
