Re: SMTA starting/ignition problems
Posted by El Toro on May 18, 2014 at 04:14:02 from (96.244.7.206):
In Reply to: SMTA starting/ignition problems posted by wicksfield on May 18, 2014 at 03:53:40:
Is there a ballast resistor being used? Check the specific gravity in each battery cell using a hydrometer and post the readings. Hal
