SMTA starting/ignition problems
Posted by wicksfield on May 18, 2014 at 03:53:40 from (67.236.246.150):
Got a buddy with a beautiful restored SMTA but it starts hard. We feel it"s an ignition problem. Here"s the symptoms:
1. Ignition on, test light bright on the battery side of the coil and on the distributor side of the coil while holding the points open.
2. When cranking the engine, the test light on the distributor side of the coil is dim and of course flickers when the points open and close.
3. The engine only starts when the starter switch is released and the engine makes one last revolution. That would be the time when the test light becomes bright again on the distributor side of the coil.
Can you guys help us out? Thanks in advance for your response.
