The issue is voltage to the ignition system while cranking. SMTA tractors need high CCA batteries 800 will do. They also need heavy battery cables because they are long, and the engine is tough to crank, If it is cold out it can draw 550 amps. The cables need to be 00gauge wire which is about 3/8 of an inch of wire diameter, not including insulation. The connections need to be soldered on and shrink tube sealed to assure tight and high amp conductivity. The ground should connect to the starter motor mounting bolt clean and shiny, then painted if needed. Welding cable, or OTR truck material is best for construction. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
