Re: At my wits end with needle valves
Posted by rustyfarmall on May 18, 2014 at 07:23:23 from (208.126.186.41):
In Reply to: At my wits end with needle valves posted by Mr. Farmall A on May 17, 2014 at 15:15:33:
I have professionally rebuilt many of those carburetors. I can tell you that for certain, if you install the new needle valve just as it comes out of the box, it WILL STICK. The solution is to thoroughly CLEAN the new needle valve and seat with aerosol carb cleaner BEFORE you install it. I never had a come-back after I learned the cleaning trick.
It seems there is a residue of some sort, left over from the manufacturing process, and gasoline does make it sticky. Get rid of the residue first, and no problems.
