Re: MD spun rod bearing
Posted by rustred on May 18, 2014 at 07:38:24 from (74.214.152.80):
In Reply to: MD spun rod bearing posted by BruceS. on May 18, 2014 at 05:17:14:
you are saying you had 75 psi oil pressure. it may be possible a brg. turned and this caused no oil to that brg. also is there oil starvation on the rest of brgs? if you were lacking oil pressure it would show on the other brgs. also. once brg. clearances are maxed out anything is possible.
as for that hole in head it maybe just a drain hole? hard to tell unless a person does a visual on the components.
