Re: SMTA starting/ignition problems
Posted by rvirgil_KS on May 18, 2014 at 07:59:29 from (8.36.243.176):
In Reply to: SMTA starting/ignition problems posted by wicksfield on May 18, 2014 at 03:53:40:
Others have identified the cause being that the starter is drawing down the battery supply so there is low voltage at the coil.
Weak battery or bad connections can be the cause.
One other possibility. Is this 6 or 12 volt system. I've seen a couple of tractors with 12 volt conversion kits give the same problem. The reason was that the supplied resistor for the coil was too high resistance. Should be 1.5 to 2 ohms, on one of mine it was 5+ ohms.
On mine I replaced the 6 volt coil with NAPA IC14SB -12 volt no resistor required- and eliminated the resistor. That cured the problem.
