400 Water Pump
Posted by JEH on May 18, 2014 at 11:08:34 from (184.18.124.70):
I'm not sure my water pump is working,I never see coolant flowing thru radiator. I have new water temp gauge coming. I took the thermostat out and checked it, it is opening and closing fine.
My question is this, witch direction does the water flow thru pump? Into the top or bottom of radiator. While I have the thermostat housing off I pulled coil wire and cranked engine. No coolant came out of the top of housing , nor did the coolant left in hosing leave or go down . Is this normal or is my pump not working?
Would like to hear your techniques for checking pumps!
Thanks!
