Re: 400 Water Pump
Posted by robgIN on May 18, 2014 at 12:31:47 from (70.224.32.140):
In Reply to: 400 Water Pump posted by JEH on May 18, 2014 at 11:08:34:
what is the actual problem you are having with the tractor ? If the water pump was not working you would have an engine that overheats , pretty quickly if working it. Depending on how the radiator is baffled inside, you may not see much movement, tell us more about what is going on and someone will be able to help you fix it.
